Question Replacement CPU Fan for Cooler Master Hyper 212 EVO
Solid_Snake3
187
Hey all,
so my CM Hyper 212 EVO fan croaked after about 5 years, so I replaced it with a cheap case fan that I got as a 4 pack for $12, which obviously isn't going to be that great. It is another CM branded fan, but it's a lot lower in RPM for one, and also my CPU temps have been slightly higher since and at load it doesn't hold up very well.
However, this was not that big of an issue as for the last year or so I have not been doing too many heavy tasks (such as video editing and gaming) due to school, but I just got the new Star Wars game and I was playing it, when my whole desktop crashed. Thinking it's a driver issue, I updated everything, which didn't help. Later, I tried checking HWMonitor, where to my horror I was seeing cores #0 and #1 hitting TJ max (100C), and I immediately shut down the game. I have an i7 4790k, and the other two cores look fairly fine, so I believe it's probably a thermal paste issue too.
I'm going home this weekend so I will definitely be repasting the thermal compound, and I feel like it's time I changed the fan too while I'm in there. What recommendations do you have?
Here are the ones I've narrowed it down to, but if you know of a better valued fan for around the same price or less, feel free to open my eyes.
https://www.amazon.com/Corsair-AF120-Quiet-High-Airflow/dp/B00F6S10MI/ref=sr_1_6?keywords=corsair+fan&qid=1576188867&sr=8-6&th=1
https://www.amazon.com/Thermaltake-...eywords=thermaltake+fan&qid=1576189220&sr=8-6
https://www.amazon.com/Noctua-redux...d_r=KM3QBYT8D856K9CVFTM4&psc=1&qid=1576188252
I also think that I should add that my thermal compound hasn't been replaced in 5 years, and I have transported this desktop back and forth long distances a couple of times, so the cooler MAY have shifted? I'm not sure, as it looks okay when I look at it.
Hey all,
I would check that the heatsink hasn't shifted or even reapply compound.
I have used the oem HYPER 212 EVO 120MM fan or the Noctua NF-P12 redux.
https://store.coolermaster.com/us/hyper-212-evo-120mm-fan-oem-package
https://www.amazon.com/dp/B07CG2PGY6
The new Starwars is brutal on a cpu. It's going to use every thread that 4790k has and ask for more. You might as well be editing or rendering.
Which is a lot to ask from a 140w budget cooler on an i7. A decent fan is going to help, reseating/repasting should definitely not hurt anything, but you can expect high temps at stock voltages on that cooler.
TDP is 88w. That's measured at Base (non-turbo) speeds and hyperthreading disabled. You can fully expect that under full 100% turbo load at stock values, with hyperthreading enabled, that cpu will hit closer to 180w, well over the ability of the Hyper212 to keep it under TjMax.
Honestly I'd strongly consider overclocking the cpu. Not by raising the speeds, but by undervolting the cpu as much as possible and still maintain stability. It's the only way (barring a change of cooler) that you'll bring power consumption and it's resultant temps down to acceptable levels.
