Replacement Fan For AMD Athlon 5350
Shadowwrath5
229
Hi I have an AMD Athlon 5350 (as seen here) in a small form mini-itx build. The stock fan is very very loud on full load and Im trying to find a replacement. Unfortunately, the AM1 form factor found on the site doesn't seem to exist as a fan size. Can anyone help me find a quiet replacement??
http://www.arctic.ac/us_en/alpine-m1.html
This is the only aftermarket cooler i found on the market currently being sold in the states. there are other options, and if you don't mind importing them from Taipei or hong kong or Austria, there are other options available.
personally if i was getting an aftermarket cooler i'd send away to japan for the Scythe Kodati Rev B. but that's me.
I was searching in the power search feature an noticed there was no check box for the am1 form factor. Now why It didnt occur to me to just search it I will never know... Sorry
Thanks for the suggestions everyone else. I think Im going with the alpine m1 just because Ive had a few of there products and they have worked great so far. Thanks again!
