Replacement for Corsair VS650
Adnan_29
Hi i am facing a lot of problems with my Corsair VS 650. i want a good replacement SMPS for my gaming rig. kindly suggest another.
Yeah, so i heard.
The details of my rig are as follows
1) amd fx 8350
2) msi 970 gaming motherboard
3) msi 970 graphic card
4) 4x4 gb ram
Looking forward to ur reply
okay I used 2 references;
1) pcpartpicker.com and it listes those details to an average usage of Total: 86W to 358W
2) outervision.com and it lists those details to an average usage of Load Wattage: 406 W
if you are NOT overclocking I can safely recommend a 550W PSU
if you are overclocking then 600w is safer yes but would need overclocking details to be sure.
next question, what country are you in ? and are you overclocking cpu or/and Gpu ?
I am from India and yes i am overclocking so i guess 600w is a safer bet?
