[SOLVED] Replacement for dns-323
xpqs
8
After years of good service my NAS died totally after what I assume was an electrical event. The problem is that it lived so long the 1TB WD10ears I used in them are no longer supported by modern NAS like the Synology DS218J I was going to purchase.
Now in this age of cloud backups and streaming media I don't really need a NAS (though it would be nice to have) but I really don't want to lose the data I had backed up on the hard drives. Would appreciate any advice on getting the data off the old drives, either by using a new NAS that can support a pair of these 1TB drives or using something else to extract the information.
thanks,
xp
Reactions: Mimisss
It has been a long time since I had a DNS323, but I think it uses EXT3 and mdadm. You might be able to boot a Linux live CD and see if you can read one of the disks with a USB adapter. If you can read the data, copy it to another drive. Then you can allow your new NAS to format the drives.
That WD is a standard SATA drive. Still supported in any current situation, NAS or otherwise.
Of course, WD Greens are NOT recommended for any NAS use.
I asked on Amazon and got the response from Synology that it did not, hence my post. I could buy the NAS and try but was hoping someone had succeed with a product I could order it with confidence that it would work.
Following up I got the Synology but it couldn't read the drives. I also tried through my USB adapter but neither my Mac or Kubuntu worked. The Mac can't read the drive and Kubuntu doesn't see any of the files 😳.
If it's ext3 I should be able to read it in some version of Linux. Any suggestions on what I can try ?
thanks,
X.
thanks,
X.
It is quite possible the disk has failed.
