Replacement for GTX 660 SLI (NOT Ti)
Izaran
57
I have a possible budget cap of $250, and would much prefer to gain in terms of performance. I'm a bit behind on GPUs these days as it is.
So, what would be an ideal replacement for my 660 SLI configuration?
Post: I MIGHT be able to weasel $300.
The 970 is the best option if you can swing for $300-$330. It's the go to GPU for 1080p gaming @ high to ultra settings @ 60 fps.
http://www.amazon.com/EVGA-GeForce-Cooling-Graphics-04G-P4-3975-KR/dp/B00R3NK2LE/ref=sr_1_2?s=pc&ie=UTF8&qid=1453491344&sr=1-2&keywords=gtx+970
My friend had dual 660ti's and replace them with a single EVGA 970. It was a night a day difference. With the 660's he struggled to run high settings @ 1080p but once he upgraded to the 970, he was enjoying 1080p at max settings. He ended up getting a second one later to play @ 1440p. They are good cards :)
This will work with your existing hardware, and you will see a big difference upgrading to the GTX 960 over the dual 660's you have now.
EVGA
http://www.amazon.com/EVGA-Installed-Backplate-Graphics-04G-P4-3967-KR/dp/B012NOWERC/ref=sr_1_1?s=pc&ie=UTF8&qid=1453490762&sr=1-1&keywords=gtx+960
or
Gigabyte
http://www.amazon.com/Gigabyte-Gaming-Graphics-GV-N960G1-GAMING-4GD/dp/B00VBNT3X0/ref=sr_1_6?s=pc&ie=UTF8&qid=1453490762&sr=1-6&keywords=gtx+960
The 960 can play 1080p games @ 60fps @ high settings all day long
