[SOLVED] Replacing Case USB Panel
maseratirex
7
I heard that you can replace the front panel on a pc case and upgrade it from USB 2.0 to 3.0. I have a RV01B-W with USB 2.0. Could someone recommend a replacement part and how expensive would it be?
Do you have a USB 3.0 header on your motherboard?
I will leave recommendation to people that bought some. I have no idea which one to recommend to you.
I’m thinking about getting a B450 Pro4 for a Ryzen 5 1600AF, so yes. It only has two USB2.0 headers though. It looks like the RV01 has external 5.25” drives, thanks for helping out!
