Replacing PSU but keeping existing power cables
Howard Banister
7
I currently have a Corsair HX750 modular PSU. It has developed a ridiculously loud buzzing noise when under GPU load, so I want to replace it. My question is can I keep the existing cables that are running to my components and replace the PSU with another modular PSU without replacing all those cables?
If you get a similar power supply, sure.
This may be representative of all the power supplies the cables should fit, but it is basically just their list of power supplies compatible with their cable sets:
AX (22)
AX, AXi, CSM, CXM, HX, HXi, RM, TXM (10)
AXi, HXi, RM (6)
RMx, RMI (6)
AXi, CXM, HX, TXM (4)
GS (3)
HX (3)
AXi (2)
HX, TXM (2)
AXi, HXi, HX, RMi, RMx, RM, SF, TXM, CSM, CXM (1)
AXi, CXM, HX, TXM, RM (1)
http://www.corsair.com/en-us/power-supply-units/psu-accessories
Late model RMi supplies use a different cable I think.
You can always shoot Corsair an e-mail and ask them.
