Question Requesting help diagnosing random BSOD issue - Have Minidump file listed below
redteamrocks
9
4
10,515
TL;DR: My PC is BSODing while playing games. It shows a whea uncorrectable error. I'm aware that this is usually a hardware issue, but can also be due to corrupted drivers. So far I've done the following to troubleshoot (nothing has worked):
  • Run error and stress tests on parts individually (All passed, no errors and did not get too hot)
  • Updated drivers
  • Reset Windows back to default (Local reinstall)
  • Removed GPU driver with DDU and reinstalled it
I was able to locate the Minidump files and I understand some of it, but not enough to really know what's going on. I'm going to paste it below, can someone please help me decipher this? Thank you!!
* Bugcheck Analysis *
CRITICAL_PROCESS_DIED (ef)
A critical system process died
Arguments:
Arg1: ffff8e8b6f5c4300, Process object or thread object
Arg2: 0000000000000000, If this is 0, a process died. If this is 1, a thread died.
Arg3: 0000000000000000, The process object that initiated the termination.
Arg4: 0000000000000000
Debugging Details:
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 1796
Key : Analysis.Elapsed.mSec
Value: 1792
Key : Analysis.IO.Other.Mb
Value: 0
Key : Analysis.IO.Read.Mb
Value: 1
Key : Analysis.IO.Write.Mb
Value: 0
Key : Analysis.Init.CPU.mSec
Value: 296
Key : Analysis.Init.Elapsed.mSec
Value: 9332
Key : Analysis.Memory.CommitPeak.Mb
Value: 83
Key : Analysis.Version.DbgEng
Value: 10.0.27725.1000
Key : Analysis.Version.Description
Value: 10.2408.27.01 amd64fre
Key : Analysis.Version.Ext
Value: 1.2408.27.1
Key : Bugcheck.Code.LegacyAPI
Value: 0xef
Key : Bugcheck.Code.TargetModel
Value: 0xef
Key : CriticalProcessDied.ExceptionCode
Value: 72488080
Key : CriticalProcessDied.ImageName
Value: ntdll.dll
Key : CriticalProcessDied.ImageOffset
Value: 9a0dc
Key : CriticalProcessDied.ImageSize
Value: 1f8000
Key : CriticalProcessDied.ImageTimestamp
Value: 688f8c4b
Key : CriticalProcessDied.Process
Value: svchost.exe
Key : CriticalProcessDied.Symbol
Value: ntdll.dll!_woutput_s
Key : CriticalProcessDied.WERReportId
Value: af78e019-03e7-4228-a537-d3a84fc9daf4
Key : Dump.Attributes.AsUlong
Value: 8
Key : Dump.Attributes.KernelGeneratedTriageDump
Value: 1
Key : Failure.Bucket
Value: 0xEF_svchost.exe_BUGCHECK_CRITICAL_PROCESS_72488080_ntdll.dll!_woutput_s_IMAGE_ntdll.dll
Key : Failure.Hash
Value: {1682f81f-cc2c-471c-da1b-ea66fa4ccbbf}
BUGCHECK_CODE: ef
BUGCHECK_P1: ffff8e8b6f5c4300
BUGCHECK_P2: 0
BUGCHECK_P3: 0
BUGCHECK_P4: 0
FILE_IN_CAB: 011925-7156-01.dmp
DUMP_FILE_ATTRIBUTES: 0x8
Kernel Generated Triage Dump
FAULTING_THREAD: ffff8e8b72488080
PROCESS_NAME: svchost.exe
CRITICAL_PROCESS: svchost.exe
ERROR_CODE: (NTSTATUS) 0x72488080 - <Unable to get error code text>
CRITICAL_PROCESS_REPORTGUID: {af78e019-03e7-4228-a537-d3a84fc9daf4}
IMAGE_NAME: ntdll.dll
MODULE_NAME: ntdll
FAULTING_MODULE: 0000000000000000
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
STACK_TEXT:
ffffe387`c534d938 fffff801`7e10ed12 : 00000000`000000ef ffff8e8b`6f5c4300 00000000`00000000 00000000`00000000 : nt!KeBugCheckEx
ffffe387`c534d940 fffff801`7e016e13 : 00000000`00000000 fffff801`7db167fd 00000000`00000002 fffff801`7db16727 : nt!PspCatchCriticalBreak+0x10e
ffffe387`c534d9e0 fffff801`7deb0c10 : ffff8e8b`00000000 00000000`00000000 ffff8e8b`6f5c4300 ffff8e8b`6f5c4738 : nt!PspTerminateAllThreads+0x15ab73
ffffe387`c534da50 fffff801`7deb0a0c : ffff8e8b`6f5c4300 00000000`00000000 00000000`00000000 ffffe387`c534dae8 : nt!PspTerminateProcess+0xe0
ffffe387`c534da90 fffff801`7dc12908 : ffff8e8b`6f5c4300 ffff8e8b`72488080 ffffe387`c534db80 ffffffff`f70f2e80 : nt!NtTerminateProcess+0x9c
ffffe387`c534db00 00007ff9`1724da74 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x28
00000085`2e9f3db8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ff9`1724da74
STACK_COMMAND: .process /r /p 0xffff8e8b6f5c4300; .thread 0xffff8e8b72488080 ; kb
FAILURE_BUCKET_ID: 0xEF_svchost.exe_BUGCHECK_CRITICAL_PROCESS_72488080_ntdll.dll!_woutput_s_IMAGE_ntdll.dll
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {1682f81f-cc2c-471c-da1b-ea66fa4ccbbf}
Followup: MachineOwner
