[SOLVED] Reset stuck at 34%
Jan 2, 2020
I started a PC reset and it has been stuck on 34% for almost 2-2.5 hours.
The laptop I am resetting is an Acer Aspire 5 with a dual SSD and HDD (128 SSD and 1Tb HDD) with 8 GB of RAM and an I7 intel processor
Is it normal with these specs to be stuck on this?
Also, is there something I can do to stop it without corrupting windows, files, etc?
I would say not normal. You might have to format the drive, and do a fresh install. It is also possible one of your drives is bad, causing the hang up.
