Question Resolution problem with Gigabyte M27Q
Dec 25, 2024
6
I’m having a persistent issue with my Gigabyte M27Q monitor after connecting it to my NVIDIA GeForce RTX 3060 laptop via DisplayPort (Lenovo Legion 5 15ACH6H).
In the Windows display settings, the resolution is correctly set to 2560x1440, and the image appears fine visually. However, when I open the monitor’s internal settings menu using the rear joystick, it shows the input resolution as 3840x2160 @ 60Hz – which I can't change, no matter what I try.
I’ve attempted to resolve this by:Forcing 2560x1440 @ 165Hz via NVIDIA Control Panel.
Switching DisplayPort cables and using HDMI.
Trying custom resolution options.
As a result, I’m stuck at 60Hz, even though the monitor supports 165Hz (and 170Hz with overclock). This is incredibly frustrating, as I can’t access the monitor’s native refresh rate, and the input resolution being locked at 3840x2160 makes no sense for a 1440p display.
which revision is it?
Rev 2.0
https://www.gigabyte.com/Monitor/M27Q-rev-20/support#dl
Firmware version F08
Rev1.0
https://www.gigabyte.com/Monitor/M27Q-rev-10/support#dl
connect the monitor with an USB cable
on the gigabyte support homepage, you can find a firmware update for your monitor. Update your current version and check again afterwards
thank you for the reply, its. Rev 2.0 and it says drivers are up to date when I try to update. I tried to change settings via Gigabyte OSD Sidekick, unlucky the newest version of the app gives me warning about having more than one gigabyte monitors pugged in (and it's the only one), the older version gives warning about not plugged usb cable (and it's plugged in)
