Resolution sound problem in acer aspire
mayline baleta
hello can i ask something regarding to my acer aspire one 722 series,because my netbook is no sound.,i already fix by my self but its did not work it and i also bring the fortress and the guy told me it has a virus and much better if i bring in KWUN TONG.honestly speaking it very far in my location.do you have any suggestion how to fix it...?thank you and godbless
Double click the speaker icon in the lower right hand of the desktop, this will bring up the mixer, or single click to bring up the volume control.
But in case the volume is missing, corrupted, or the audio is otherwise non-functional:
you check whichever audio was installed:
click start, control panel, add remove programs, look at the list...
which audio software is shown on the list? delete it, restart the computer.
now visit the motherboard manufacturer or computer manufacturer's website
look up your computer drivers by model number
download the latest audio drivers, save on the desktop...
turn the antivirus off,
if you have multiple security programs installed, turn them all off
(your driver may not install if security systems are turned on)
now load your new audio driver, restart, turn the antivirus back on.
