Question Resource Monitor fan speed and image path from specific path?
DynV
288
5
18,785
On Windows 10, Resource Monitor showed only 60 seconds so I loaded Performance Monitor, increase the duration then added the counter Processor Time. Is there a way to add the 2 following counters?
  1. CPU fan speed,
  2. the total of processor time of all the process that the image path is from a specific path and all subdirectories?
Thank you kindly
Not really sure about the full requirements.
However, take a look via PowerShell - there are a number of cmdlets and means to obtain additional system information.
E.g. Get-Process
Reference:
https://learn.microsoft.com/en-us/p...ll.management/get-process?view=powershell-7.4
More information can be obtained via Get-WmiObject and its' successor Get-CimInstance.
Very likely that you will be able to start with a basic Get and expand the cmdlet to obtain the required details.
