Hi guys.
I recently upgraded motherboards to an Asus Prime X470 Pro and am having this annoying issue: When I power on the PC for the first time, the fans and HDD spin up during POST but then I get two very short beeps. It then restarts, POSTS properly and boots into windows fine.
I suspected a faulty RAM stick but I've run several tests with windows memory diagnostics tool, which is showing no errors on any stick in any DIMM slot (tried all possible combinations, and I can't get anything but a faultless result. I'm running a 4x4GB setup and I don't get the beeps if I use 1,2 or 3 sticks, but it always restarts regardless of the RAM configuration.
What's strange is that if I shutdown the PC but leave the PSU switched on, it will boot first time the next time I power it up with no beeps and no restart.
I've checked all cables and made sure they're all plugged into the correct places and reset the BIOS to defaults. I've not tried reseating the CPU cooler, but as my temps are fine in games I don't think it could be that.
Games and applications all run well, and I'm not getting any CTD or BSODs but as this board doesn't have a digital code display or even LEDS I'm struggling to find the cause of this.
Any help would be greatly appreciated
