Isaiah Banker Reynolds :
i have a delta 350 watt power supply that im using in my current build and i was wondering if i should switch it out for another one or just use the same im switching from a core 2 quad to and amd fx so saving 30 watts of power
You can but you want to make sure that if you upgrade other parts, i.e. video card, that it falls under the recommended requirements. For systems today I wouldn't recommend anything under 500W (quality one) unless you don't do gaming or video editing.
Also, since you are getting a new processor, this equally means that you are getting new motherboard along with your CPU (and possibly memory). Like others above, you may want to really consider and invest in a good power supply. PSU's are probably the most important part of your system and reusing older ones can cause issues that you may not have the knowledge or ability to figure out - BSOD's, system restarts, etc... You can also get power shorts, burns or under/over voltages which will ruin your new hardware.
Just something to consider
