Revamping Old Build, need tips
willthenarwhal
70
Case - NZXT S340 WHITE
GPU - MSI GTX 1080TI
MOBO CPU COMBO - Intel 7th Gen Intel Core Desktop Processor i7-7700K w/ Intel Optane Memory Module 16 GB PCIe M.2 80mm & ASUS ROG Maximus IX Code LGA1151 DDR4 DP HDMI M.2 Z270 ATX Motherboard\
Cooler - Hyper 212 evo
PSU - Corsair CX Series 750 Watt 80 Plus Bronze Certified Modular Power Supply (CP-9020061-NA)
Storage - Same moving them over but adding 2 tb possibly of whatever.
_________________________________________________________________________
Ok thats the new parts, and im moving RAM and Storage from the old system over. Will I have any issues, and would any of you make any different recommendations.
Also I would really love a compatible cpu fan, thats RGB but also easy to install, because the hyper 212 evo I havent had a great time with before, reccomendations?
psu is not very good. Are you sure your old ram is ddr4? If ddr3, incompatible. Get coffee lake if you have the budget!
My edits for your parts:
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor ($399.99 @ B&H)
CPU Cooler: Deepcool - CAPTAIN 120EX RGB 76.5 CFM Liquid CPU Cooler ($84.79 @ SuperBiiz)
Motherboard: ASRock - Z370 Extreme4 ATX LGA1151 Motherboard ($158.99 @ SuperBiiz)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory ($154.99 @ Newegg)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($59.99 @ Amazon)
Video Card: Asus - GeForce GTX 1080 Ti 11GB Turbo Video Card ($709.99 @ Amazon)
Case: NZXT - S340 (White) ATX Mid Tower Case ($61.99 @ SuperBiiz)
Power Supply: Corsair - TXM Gold 650W 80+ Gold Certified Semi-Modular ATX Power Supply ($79.99 @ Newegg)
Total: $1710.72
Generated by PCPartPicker 2017-11-06 20:52 EST-0500
If too much, I5-8600k can replace.
My old ram is vengeance LPX ddr4 it is perfectly fine. I was wondering if I could get coffee lake with maybe a bit of a better MOBO. And its 1151 correct?
Seeing that I feel like Kaby Lake is just the better option for me personally, I will stick with your PSU choice. Will everything I picked be considered go together rather easily?
No sorry if i made that unclear.
I only need it to last me a good 3 - 4 yrs
