Hello, I would like anyone reading this to review the parts that I am planning on buying to build a budget AMD build. If you can please correct me if the components I have are not good/suitable or if I can find cheaper parts. According to my calculations, this build will cost me about 470€ (531$), if you can can you please tell me if I can make a more powerful build with the same amount of money?
Specs:
CPU: Ryzen 3 2200G
Motherboard: Gigabyte B450M DSH3 Micro ATX
RAM: 2x4 HyperX Predator DDR4-3000MHz
Storage: HDD WESTERN DIGITAL 1TB CAVIAR BLUE SATA3
Case: Cougar MX330-X
PSU: Thermaltake Smart RGB 500W
Case Fans: x2 Cooler Master SickleFlow Led Green 120mm
Monitor: AOC M2060SWDA2
Specs:
CPU: Ryzen 3 2200G
