Build Advice Review my build
Flake.
20
aesthetics build
Im planning on building this high-end pc and need someone to review it ( if im missing anything out)
planning on playing 2k@144+fps on it
https://pcpartpicker.com/list/BjKtfy
also gonna add a strimer plus v2 24pin and a 8x2 pin to the motherboard and gpu
Im i need to add any type of hub, controller or anything like please let me know
Reactions: artk2219
Another option to consider.
PCPartPicker Part List
CPU: *AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor ($344.99 @ Amazon)
Motherboard: *Gigabyte B650 AORUS ELITE AX ICE ATX AM5 Motherboard ($229.88 @ Amazon)
Memory: *TEAMGROUP T-Force Delta RGB 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($106.99 @ Amazon)
Total: $681.86
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2024-05-26 15:22 EDT-0400
intel fan here 🙁
Reactions: artk2219 and Why_Me
intel fan here 🙁
Then look at the 13700K / 13700KF.
How glued to the aesthetics are you? You could spend less on the aesthetics and end up with a 4080 / 4090 instead of a 4070 ti super. Contemplate the below builds:
CPU: Intel Core i7-13700K 3.4 GHz 16-Core Processor ($329.98 @ Newegg)
CPU Cooler: Thermalright Phantom Spirit EVO 69 CFM CPU Cooler ($49.90 @ Amazon)
Thermal Compound: ARCTIC MX-6 4 g Thermal Paste ($6.55 @ Amazon)
Motherboard: ASRock Z790 Lightning WiFi ATX LGA1700 Motherboard ($169.99 @ Newegg)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL32 Memory ($98.20 @ Amazon)
Storage: Acer Predator GM7000 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($84.99 @ Amazon)
Storage: Crucial P3 Plus 4 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($237.99 @ Amazon)
Video Card: Asus TUF Gaming OG OC GeForce RTX 4090 24 GB Video Card ($1751.00 @ B&H)
Case: Lian Li LANCOOL 216 ATX Mid Tower Case ($99.99 @ Amazon)
Power Supply: SeaSonic FOCUS GX-1000 ATX 3.0 1000 W 80+ Gold Certified Fully Modular ATX Power Supply ($139.99 @ Amazon)
Total: $2968.58
Generated by PCPartPicker 2024-05-28 12:45 EDT-0400
Video Card: PNY XLR8 Gaming VERTO EPIC-X RGB OC GeForce RTX 4080 SUPER 16 GB Video Card ($999.99 @ Newegg)
Total: $2217.57
Generated by PCPartPicker 2024-05-28 12:44 EDT-0400
Reactions: artk2219
Do not attach yourself to corporations, they do not care about you. Just buy what is best and in your budget.
Agree completely. Right now the 7800x3d is the gaming king, and AM5 gives you an upgrade path, where as Intel currently does not. I also see a good deal of overspending in this.
AMD build, keeping your visual theme but with less expensive components. You get a faster GPU, for less money too.
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor ($344.99 @ Amazon)
CPU Cooler: Deepcool LS720 SE WH 85.85 CFM Liquid CPU Cooler ($89.99 @ Newegg)
Motherboard: Gigabyte B650 AORUS ELITE AX ICE ATX AM5 Motherboard ($219.99 @ Amazon)
Memory: TEAMGROUP T-Force Delta RGB 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($106.99 @ Amazon)
Storage: Crucial T500 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($138.99 @ Amazon)
Video Card: Gigabyte AERO OC GeForce RTX 4080 SUPER 16 GB Video Card ($1149.99 @ B&H)
Case: Deepcool CH780 ATX Full Tower Case ($120.98 @ Newegg)
Case Fan: Deepcool FC120 WHITE-3 IN 1 61.91 CFM 120 mm Fans 3-Pack ($34.99 @ Newegg)
Monitor: LG 27GR95QR-B 26.5" 2560 x 1440 240 Hz Monitor
Total: $2485.89
Generated by PCPartPicker 2024-05-28 13:05 EDT-0400
If you insist on staying with Intel.
CPU: Intel Core i7-14700K 3.4 GHz 20-Core Processor ($389.99 @ Amazon)
Motherboard: Gigabyte Z790 AORUS ELITE AX ICE ATX LGA1700 Motherboard ($249.99 @ Amazon)
Total: $2560.89
Generated by PCPartPicker 2024-05-28 13:07 EDT-0400
No, no. The 13th gen i7 is lame. It's the one place the 14th gen brought a significant improvement.
I dare say the 14700K is the best CPU of the 12/13/14 gen lot. The 14900K is faster but it's price and the nonsense with overboosting makes it less desirable for home and gaming use.
In my opinion anyway.
Here is my suggested 14700K build:
CPU: Intel Core i7-14700K 3.4 GHz 20-Core Processor ($389.98 @ Newegg)
CPU Cooler: be quiet! Dark Rock Pro 5 CPU Cooler ($79.90 @ Newegg)
Motherboard: Asus ROG STRIX Z790-A GAMING WIFI II ATX LGA1700 Motherboard ($335.99 @ Newegg)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($104.99 @ Newegg)
Storage: Samsung 990 Pro 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($124.99 @ Newegg)
Storage: TEAMGROUP MP44L 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($116.99 @ Newegg)
Video Card: Gigabyte WINDFORCE OC GeForce RTX 4070 Ti SUPER 16 GB Video Card ($799.99 @ Newegg)
Case: Fractal Design Meshify 2 RGB ATX Mid Tower Case ($184.98 @ Newegg)
Power Supply: SeaSonic VERTEX GX-1000 1000 W 80+ Gold Certified Fully Modular ATX Power Supply ($149.99 @ Newegg)
Total: $2404.79
Generated by PCPartPicker 2024-05-28 17:51 EDT-0400
How attached are you to that Asus motherboard?
The Gigabyte Aorus Elite X WiFi 7 is cheaper and i'll be switched if i can tell in what way it's worse.
https://pcpartpicker.com/product/MZ...-lga1700-motherboard-z790-aorus-elite-x-wifi7
The liquid cooler is a waste of money. It will not be neccessary at all. A number of air tower coolers will do the job, including the suggested Dark Rock Pro 5.
Alternatives are the Scythe Mugen 6, Thermalright Peerless Assasin or Phantom Spirit EVO, Noctua NH-D15. There are many.
You can still buy the custom paste if you like, but it's not neccessary.
With memory, you want lower latency (CL) for gaming. CL28, 30 or 32 are acceptable.
You can go with any kit, but watch the latency!
Samsung 990 Pro has speed and durability but that speed is not noticeable 95% of time. You could go with much much cheaper NVMe without risking too much in quality or performance.
But i don't blame you for buying quality. I would suggest you pick a smaller Samsung to be your OS drive, and use another for storage. I picked two 2Tb MP44L drives that are reliable and affordable. You can ditch one to save a bit of money.
Pick any 4070 Ti Super you like. You could opt for a RX 7900GRE and save a bit of money without losing out much on performance. QHD @ 144Hz is 7900GRE's playground.
If you really want a case like that, consider the Antec C8: https://pcpartpicker.com/product/dF9wrH/antec-c8-atx-mid-tower-case-c8-wh
140mm white aRGB fans: https://pcpartpicker.com/product/cL26Mp/be-quiet-light-wings-717-cfm-140-mm-fans-3-pack-bl103
(1 rear, 2 side, 3 top or bottom)
I would much rather have a Meshify or Torrent. The Torrent has far better airflow and ventilation.
https://pcpartpicker.com/product/BjqPxr/fractal-design-torrent-atx-mid-tower-case-fd-c-tor1a-01
No comment about your monitor.
you've made a few mistakes and overspent on items that don't improve quality or performance. I would recommend spending on quality. Cheap stuff just doesn't make life better.
That said, there is very little reason to avoid a decent NVMe that is not noticeably slower, or an air cooler that does the job exactly as well as a liquid cooler.
Enjoy your build. Hope the advice is useful.
The 14700k was not any improvement for gaming, and not much for production.
View: https://www.youtube.com/watch?v=8KKE-7BzB_M&t=941s&pp=ygUNMTQ3MDBrIHJldmlldw%3D%3D
Reactions: Why_Me
