Dogsnake :
Please let me know a few things. At this time you have tried to uninstall the Lexicon product? Are you insistent on using it if it can be installed again (no guarantee it will work as it did not show in the Sonar the first time)? As it is now does the rest of the system work correctly? I can suggest registry changes that may solve the install issue but will not insure the entire thing will not repeat. Last have you tried a system restore to a point prior to the Lexicon installation?
Hi DogSnake,
Yes I I did try a system restore, and it didn't fix the issue. In answer to your question. I would like to use the Lexicon software if I could, but more importantly I don't want to screw up my PC. Also...yes...the rest of my system is working fine. I also have installed the "Lexicon Native Reverb Bundle" and it works fine. What baffles me is when I did install the plug-in the first time with no issues the dll's of the" Lexicon Native Effects Bundle" were in my vst plug-in folder(like the rest of my plug-ins that work and are recognized), yet Sonar X1 does not show the "Lexicon Native Effects Bundle" when I open Sonar. It looks like they didn't load or something.
When I tried putting the dll's of my problem Lexicon("Lexicon Native Effects Bundle") into the working Lexicon folder ( "Lexicon Native Reverb Bundle") then opened Sonar they were recognized and started loading, but half way I got a message saying "User privileges insufficient to start a low level driver" and they stopped loading. Tried again as an administrator but same thing. I have in the past moved dll's that are not recognized by Sonar to vst plug-in folders that Sonar recognizes and it works...Sonar then will recognize them. I know that with running 64bit Sonar sometimes has issues with some software that are still 32bit, but Sonar has a bridging thing going on, and if that does not work. I use a software called jbridge that always does the trick. The working Lexicon ( "Lexicon Native Reverb Bundle") works fine and it's bridged. Reason I'm telling you all this is I'm wondering if the bit rate has anything to do with it(with regards to Sonar X1 not recognizing the dll's). I still have the installed dll's from the not working Lexicon in my recycling bin from when I installed the first time before uninstalling it. Is there a way to use them, or do I need to fix the original run time error problem at hand and re-install from scratch? Just to let you know I did try installing it on my other PC and it did install, but I have no Sonar to test if it works, just that it did install with no problems(also running windows 764bit).
I'm sorry if I put out too much info, but I know it give you more to work with, with regards to my issues.
Please let me know what I can do to hopefully fix the run error and hopefully use the software.
I can't say thank you enough for you effort on this matter!!!
John
