[SOLVED] Rgb cable not compatible with header on Asus motherboard
KnightyKnight96
Commendable
Oct 25, 2016
7
Hi guys,
I recently bought the following case:
Thermaltake view 31 Tg Rgb edition
And the following motherboard:
Asus prime z390-a
The case comes with Rgb fans that use a cable that connects to a little board on the back of the case which has 3 holes on the motherboard's end but the motherboard only has a 4-pin aura rgb connector and therefore I am not able to connect it. Also the header on the motherboard is 12V whereas the cable is 5V.
Am I right to assume I will need to buy a separate connector or rgb controller? If so, is there any you would recommend?
I attached a picture of the cable I've got and a sheet that came with the cade which explains how to connect the rgb to the motherboard. Thanks and have a lovely day!
View: https://imgur.com/a/VPuw1XW
View: https://imgur.com/a/kthbxGB
View: https://imgur.com/a/rAcu51x
12v is normally for strips not argb fans. Your board doesn't have an argb fan header. You'll only find that on higher grade boards not the budget offerings.
Internal I/O Ports
2 x Aura RGB Strip Headers
You'll need a seperate argb controller that's compatible with the TT fans. Addressable RGB (ARGB) is not the same as RGB. Rgb is 1 solid color at any given time to all the leds, ARGB is seperate colors to seperate leds which can also be a solid color. Basically ARGB is capable of a Rainbow affect, RGB is not.
Internal I/O Ports
Thanks a lot for your help! Is there any controller you'd recommend?
I found a few online but I don't seem to be able to identify whether they are compatible with my fans. There is a TT one but it says its only compatible with 5v argb motherboards.
