RGB Case but no RGB Header on motherboard
greentent
So I am in the market for a nice tempered glass case ($200 max) and it seems like all the nicer cases have rgb which i would love. The problem is that I have a z97x gaming 5 mb and it doesnt have an rgb header. Is there any workaround like a controller? Or am I stuck with plain jane cases?
It depends on the case you are looking at. Cases like the Corsair 460X and 570X RGB come with a built in controller. You can also buy a controller box. Like this one from Aerocool. You can get it with fans as well.
https://www.box.co.uk/Aerocool-Project-7-P7H1-RGB-PWM-Fan-Hub-_2190120.html
with fans
https://www.box.co.uk/Aerocool-Project-7-3-x-P7-F12-Fans-16.8-_2190119.html
I hope this helps.
with fans
I hope this helps.
