[SOLVED] Rgb control
Aug 7, 2019
I have a raidmax case 6 raidmax rgb fans and 2 raidmax rgb strips and am looking for a rgb controler for all of it but I don't know what controller is cunpatibel can someone help thnks
corsair commander pro is exactly what you need
its quite pricy at 75$, but it has 2 rgb strip ports and 6 fan ports
all it needs is 1 internal usb 2.0 header and it has another one on it so if you dont have any of those
free atm you dont need to worry.
Reactions: Lazzyy
Paperdoc
Polypheme
Ambassador
Tell us exactly what model of Raidmax case you have.
Also look at the fans. Tell us what model number is on them. Are they all the same? of some different?
Then, tell us what MOBO you have - maker and exact model number. It may be that your mobo has all you need for this, but maybe not.
