Ive just purchased a Cooler Master Mastercase which comes with 2x 200mm RGB fans which your supposed to be able to connect to your rgb header on your motherboard but the 3 pin connection from the fan is something i haven't seen before, i have no idea to to connect that to the 4pin RGB header, i even purchased the Coolermaster rgb extension cable which is supposed to be for that exact purpose. i have added pictures.
