Question RGB/Fan Controller?
Any suggestions for a controller? I am building the following system and would like to know if there is a controller that would be great for RGB, fan controlling, etc.
https://pcpartpicker.com/list/8tXDFZ
Everything is already built in the MB and cooler. Don't need any controllers. Fan motors can be controlled thru BIOS and/or software and (A)RGB lights thru software from MB manufacturer's site or 3rd party.
Reactions: Paperdoc
OP, IF your mobo does not come with BOTH of its manuals, make sure you download them from the website for the mobo. One is called just the Manual and contains details of what features are where. The other is called the BIOS User Guide and contains details of how to choose custom settings in the BIOS Seetup screens. The basic Manual shows on p. 51 the several fan MOTOR headers for your different fans, and each will do automatic control of the fan motors. On p. 54 it also shows the mobo contains three JRAINBOW_V2 headers to which you can connect the LIGHTING cables from each fan. These power and control the lights in your fan frames, using a software tool called MSI Mystic Light that will be included on the CD disk of utilities.
Reactions: CountMike
I'll offer a few hints. Remember that the CPU cooling system is different from the case ventilation fans.
The Arctic Liquid AIO system comes with a choice of two cable types to connect the pump to the mobo. The simpler All-In-One Cable plugs into your mobo's CPU_FAN header and provides power for all three components of the system: the pump itself, the VRM cooling fan in the pump body, and the three Rad Fans (this latter via wires in the hoses to the rad). This system uses the PWM speed control signal from that header to control speeds of all three parts, and reports to that header the speed of one Rad Fan only. For someone new to PC building this system is recommended because it is easy and requires NO customization.
The more complex Individual Control Cable requires connections to THREE mobo fan headers, and allows you to customize (if you wish) cooling details for those three key components separately. As a side "bonus", this means the speeds of the Pump, VRM fan and one Rad Fan will all be "seen" at their respective headers. For your mobo, OP, I suggest that IF you use this cable you connect the Rad Fans cable to the CPU_FAN header, the PUMP cable to the PUMP_SYS1 header, and the VRM cable to the SYS_FAN1 header nearby. Then you will need to configure each of those headers in BIOS Setup appropriately - see the lower sketch on p. 18 of the BIOS Setup manual. At upper left you can select each fan header in turn to adjust it. For all three I suggest at upper centre you set Smart Fan Mode ON and Fan Type Auto Detect Off, then below that set the Fan Type to PWM, not to DC. At bottom centre for all select Set All Default and let it use its pre-programmed "fan curve". AFTER some experience if you need to you can come back and alter any fan curve.
Each fan header uses a tempearture sensor to guide it, and your mobo has several available - make the choices at upper right. For the CPU_FAN header (rad fans) set that to CPU Core, no matter whether you use the All-In-One Cable or the Individual Control Cable. If you use the latter, then set the PUMP_SYS1 header (pump control) to CPU Core also. All the other temp sensors on that list are locations of components on the mobo. But for the VRM cable from your cooler system, the most relevant sensor still is the CPU Core, so set the SYS_FAN1 header where you have this cable connected that way.
You have not told us any case ventilation fan details - how many, which maker and model. So I will assume you have several that are the newer "4-pin" PWM fan motors with three-pin ARGB lights in their frames. Each will have separate cables for its motor and its lights. For the motor cables, your mobo has six SYS_FAN headers. You MAY have used one for the VRM connector of the Individual Control Cable option, so you may have five left for case fan motors. Often that will suffice - depends on your fan count. When you configure these headers in BIOS Setup most settings are like those above, but the Temperature Sensor to specify is the System one. Assuming (again) that you have 4-pin PWM fans, for each SYS_FAN header ensure that the option near upper left is set to PWM and not to DC. (MSI often sets these headers by default to DC.)
Regarding LIGHTS, the AIO system has one cable from the Pump for that, and each case fan also will have its cable. On the mobo do NOT attempt to use the 4-pin JRGB1 header at bottom rear. You must use the three JARGB_V2_n headers for ARGB lighting systems, but you may have more than three light units to connect. So you'll need an ARGB light SPLITTER. Here is an example of one with four outputs from one mobo header.
https://www.amazon.com/YAODHAOD-Splitter-Addressable-Extension-Computer/dp/B0CWKRPV79/ref=sr_1_1?crid=1858AQRQ4XA66&dib=eyJ2IjoiMSJ9.YYO8EJm659y0IT7SYv1vfD0JrsFi8qO6v3n3UQKYAtE8lCePviDcrNf-9lTXMQpbTLnCdCmWYoPzMKTzlbbUz_e8eSa4nsy5AyhJ0QP3j992LtAZYw6RksfhvkR4a-Tr9mjcT4oVdeHGPb167h2Pay7eGpZogLhX2yJ4t0Yu0wb2cUmbgNmpx7MbZnzyD_bb2gesO8_KDkrGmeMvfHcjx67dFoM6Tixg6vieLwZxG-w.veK5ghTmLRRmt5qj4MXkUWMnpOyOf7B8O5pIomQBh_M&dib_tag=se&keywords=argb+splitter+cable&qid=1748621457&sprefix=ARGB+splitter,aps,126&sr=8-1&th=1
There's a wrinkle in ARGB lights that impacts two factors for you. There is a new version (called V2, surprise!) of ARGB that is different from the original, and your mobo can handle both. You have to choose based on the lights you have to deal with. I'm pretty sure that the lights in the AIO system are Original type. You need to check what lights are in the case fans. IF they are different, the mobo manual says you can NOT mix the two types on one lighting header using Splitters, so keep them separate. Then you may need to make a small adjustment one time. Most ARGB_V2 systems can be set to send out control signals either in the older Original version or in the new V2 version, and this would be done in the MSI utility Mystic Light. Often such systems are set by default to new V2, and that does not work for older Original lights. So IF your lights do not work, look in Mystic Light to find a place to specify whether to use Original or V2 control. This MAY apply to all three headers, or MAY be individually set for each - no notes about this in the mobo manuals.
