Hi everyone,
New to building PC's, I just bought an Aorus X570 Master installing it into a Cooler Master MB520
The case itself comes with 3 RGB fans connected to 1 RGB header connector to my motherboard
I believe the X570 Master has 1 RGB header and 1 ARGB Header
I'm assuming the RGB header will plug with the 3 fans from the case I already have
I want to install 3 more RGB Fans which is a separate kit and was hoping I could sync them all ICUE2.0 software.
The 3 RGB fan kit comes with a fan controller ; my question is - can i directly just install the RGB fans directly to the fan connectors on the motherboard and it will control all the fans together (Both power / speed & lighting? ) or will i need to install the fan controller as well.
If i install the fan controller; Would this also need to connect to the RGB header? If so do i need a splitter ?
Sorry its a bit confusing.
Any help would be great, I'm new to all these terms but trying to build this myself for the first time!
