[SOLVED] Rgb front fan connection help
Dec 14, 2018
adarraga2502
So I bought the cooler master master case lite 5 rgb but I didn’t know that you have to have a rgb header on ur motherboard so I also ordered the asus rog strix b250h gaming motherboard but I don’t know if it has a rgb header my question is does it have a rgb header if so where on the motherboard
The solution is to use the Cooler Master RGB controller.
Cooler Master RGB Controller/Hub for Computer Case Fans, Software supported, 4 Connecting Ports, USB Link, Multiple Light Modes, Color Customization
https://www.newegg.com/Product/Product.aspx?Item=9SIAFJ87N02260&Description=Cooler%20Master%20RGB%20controller.&cm_re=Cooler_Master_RGB_controller.-_-11-999-379-_-Product
I don't think it does have a RGB header. It isn't listed in the Internal I/O Ports, and I didn't see any reference to it in the overview.
Internal I/O Ports
1 x AAFP connector
2 x USB 3.1 Gen 1 connector(s) support(s) additional 4 USB 3.1 Gen 1 port(s)
1 x USB 2.0 connector(s) support(s) additional 2 USB 2.0 port(s)
1 x M.2 Socket 3 with M key, type 2242/2260/2280/22110 storage devices support (PCIE 3.0 x 4 mode)
1 x M.2 Socket 3 with M key, type 2242/2260/2280 storage devices support (SATA & PCIE 3.0 x 4 mode)
6 x SATA 6Gb/s connector(s)
1 x CPU Fan connector(s)
1 x CPU OPT Fan connector(s)
2 x Chassis Fan connector(s)
1 x AIO_PUMP connector
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x System panel(s) (Chassis intrusion header is inbuilt)
1 x Clear CMOS jumper(s)
1 x 14-1 pin TPM connector
https://www.asus.com/us/Motherboards/ROG-STRIX-B250H-GAMING/specifications/
Dec 14, 2018
Shit man that’s not good do u know what the solution is if your motherboard doesn’t have rgb headers and u need them?
