Question RGB FUSION 2.0 does not start up
Feb 26, 2025
8
Hello everyone! I received my new gigabyte CG and I wanted to install RGB Fusion 2 but it never launches. The icon appears in the taskbar but disappears immediately. Has anyone had this before? Thanks a lot!
Try and uninstall the app, then manually reinstall the app in an elevated command, assuming you're on Windows OS. Out of curiosity, where did you source the installer for the app?
Thanks for your reply. I've already tried to reinstall it but it doesn't work. And I had the problem before, I reinstalled windows a few days ago and still the same. From what I've read on the internet, a lot of people are also having problems with this software... And I found the link here (the first one):
https://www.gigabyte.com/Support/Utility?kw=rgb+fusion&p=1
