Hi all,
A quick question, I have the Strix H370-I motherboard with one addressable RGB header.
I want to add three RGB devices to my system, 2 x Phanteks Halos fan frame and 1 x LED Strip. Here is the link to the Halos https://www.amazon.co.uk/Phanteks-PH-FF120RGBP_BK01-Halos-density-mounting/dp/B074Q65CRV
I haven't decided yet on which strip.
The question is how do I connect all three devices to the one ARGB header on the H370-I?
Can I daisy chain them from one device to the other?
Or do I need a hub? If so does the hub need to be powered from the PSU via Sata or Molex?
The manual is below if anyone would be kind enough to take a look
www.asus.com
Many thanks for any help you can provide.
Cheers
||ASUS United Kingdom
Cheers
