Hello All,
Full disclaimer: Total newb when it comes to RGB Lighting, so hoping to learn a bit and get some help. I am looking for assistance with getting all of my RGB on the same page. In a nutshell, I bought a DIYPC D480 case that has a remote controlled fan/LED hub. I can control fan speed, RGB lighting effects, etc. from this hub via an IR remote. This hub DOES NOT connect to the motherboard, it is powered via MOLEX and plugs directly into the PSU. My motherboard does not support Aura so that isnt an option here. The fans and case look great! The problem I am having is that I also have an RGB LED graphics card support and want to connect that to the hub to sync everything. Turns out the GPU support has a typical aura 12V 4 pin connector and attaches to a different IR sensor. The hub does not have a slot big enough for the 4 pin aura plug-in that came with the GPU. Currently, the two RGB effects are not synced and they operate off two different remote controls (super annoying!). I figure there must be an adapter out there that connects 4 pin aura (GPU support) to a small 4 pin LED input (on the hub) [maybe 8mm LED?] so that the GPU support LEDs could run off the same hub instead of running to a whole different IR remote. I tried the two products below and struck out. Both 4 pin male inputs for these are too big to fit in the hub that came with the PC case.
Phanteks RGB LED 4 pin adapter: https://www.amazon.com/gp/product/B01BZIBJAK/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
Barrow 12V Motherboard to Barrow RGB Adapter Cable: https://www.newegg.com/p/9SIA9F962T9740
So ultimately, my question is, do they make 12V aura to small 4 pin LED adapter that could connect the GPU support LED to my main hub so all RGB can sync up? I have included photos/diagram of the hub and current setup linked. The PC case that this came with is here: https://www.newegg.com/p/N82E16811353136. DIYPC support has not replied to my email to support. Hoping to gain some clarity before I throw more money at possible solutions. Thank you in advance for your help!
