Question Right angle fittings?
quakebo
55
I am building a new pc and this time going to use hard rigid tube. Now I see a lot of people seem to use right angle fittings on the cpu and gpu blocks is this necessary or can I just use compression fittings and bend the rigid tube to fit?
The hardware I am using will be.
EK Coolstream se 360 radiator 27mm thick
Coolgate 360mm radiator 35mm thick
Pc 011d Distro plate G1 EK Waterblocks
Barrow acrylic micro jet cpu waterblock lrc 2.0 rgb am3/4 black
EK waterblocks ek-hd tube 10/14mm 500mm acrylic
Barrow G1/4 - 14mm od anti off rubber seal hard tube compression fitting - black
Graphics card undecided so do not know what block I will be using
Update your post to include full hardware specs.
What tubing are you using?
Bending and installation must be within the manufacturing specs/limits for the tubing.
However, that said the tubing and connections must likewise be in accordance with the guidelines and installation requirements for the cooling components being connected.
More information needed.
Reactions: quakebo
