Rj45 crimping issue
Aug 11, 2018
4
Hi I've crimped some cat5 rj45. However when ever i test itv using my tester pin 7 always fails. Ive done a new crimp on a short section on both ends and the fault keeps repeating.
Ive tested another cable and the tester is Working correctly.
Any ideas on what i could be doing wrong
Take a picture from the end to show the wires all the way to the end and the relative height of the crimped pins.
If you are going to make a lot of RJ45s, getting a good crimper is a must. Even cheap RJ45 plugs can be an issue. I have had batches of RJ45 that just didn't crimp well.
