Rj45 Rj 11 conversion required
Shivamagg2008
I have an adsl modem router d link dsl 2750u which has input rj11 cable(telephone cable)
.Now I want to change my Internet service and they provide a connection with rj45 male and say that I need to buy a new modem if I have to use wifi whch I dont want to.
Is there any way around that I could use my current modem to work with that rj 45 connection?
There is no way to use your ASDL modem into a cable modem, or router, or even access point. ADSL modems are not very flexible, like other devices often are.
You need a new modem and a router or a combination product, although I prefer the separate components for the ability to upgrade and the greater flexibility of a router, particularly those that are supported by other firmware (such as dd-wrt).
Who is your ISP?
I currently am using MTNL, but planning to switch over to ani networks.
