G
Guest
Guest
Archived from groups: alt.games.the-sims-2 (More info?)
Ive noticed something quite annoying. Whenever i want to make my own roof,
ie using the roof editing tools, the roof always goes into the room
partially. So even if i would like to have the roof lean against a wall i
get an ugly effect on the inside, because when i release the mouse button it
fits the roof to the squares i want it to be on and it goes that little bit
extra to the sides - through the wall and into the room.
This bugs me, although the only solution around it i have found so far is to
disable all show roof options when on that floor, that is have the walls up
or down...
Is there another way around this?
or down...
