I have just built a new pc in rosewills thor case. Even with a Noctua nh-d14 cooler I am only able to get my overclock to about 4.2 before my temps start running up. I am pretty stable at 4.3-4.4 but I don't want to run it in the 80 degree range under stress. I was considering replacing some of my stock case fans to see if I could bring the temp down enough to at least get a comfortable 4.3 overclock. At the least I want to pull the 230mm side stock fan and put a 4x120mm high flow setup to get more direct cooling to my GPU array. Will replacing the stock fans really make a big temp difference with this setup? The stock fans are pretty solid but i can't find any info on how much air they move compared to some of the higher end fans. If replacing is a solid upgrade then what fans can I get in the 120mm and 230mm sizes that will give me the best bang for my buck? I don't mind a little fan noise as long as we're not talking about a leafblower under my desk, so cooling power>silence in my case.
