Rosewill thor v2 fan led
devencoffey
5
Hello, I just got my v2 and absolutely love it, only problem is i have no idea how to get the red led on the front fan to work??? Anyone know how that has this case?
I'm not really sure that there is a button on the outside, but try looking at the inside of the case where the fan is located, you'll find it.
well what i have found is the wire for the LED but it is actually soldered into the front panel of the case... and at the solder point there is what looks like a male 3-pin power connector... but it wont work with any connectors i can find, idk what the hell is going on as the manual has nothing on this...
I'm sure you found it but. .. There's a button on the outside of the case, front panel, bottom right between the grooves. Tiny little black peg.. that's your LED button.
