Question Round PCI-E Riser Cable?
Jul 12, 2019
Hello,
Does anyone know if there exists a round PCI-E riser cable? I've tried to find one but I can only find flat ribbon cables. Is there a reason they're all like this?
I'm planning a new build and a cable with a round profile would make routing/cable managment easier.
Thanks in advance.
Well, yes.
PCI-E riser cable?
PCIe starts long and flat, and terminated long & flat, so just continuing a flat makes the most sense. I'm not even sure how you could get it into a round cable that didn't end up having to be ridiculously thick.
What is it you're trying to achieve? Is this PCIe riser to be used to vertically mount a GPU? Or something else?
If a vertical mount, the GPU itself should hide the cable?
I'm planning something like this:
A flat cable works fine with one GPU but I will have at least two. It makes cable management a bit tricky.
It's not a huge problem though. I haven't finished working everything out yet so I'm sure I can find a way around it. I was just curious really.
Thanks for your reply.
Hi rsuleyman,
Have you figured out if round PCI-E x16 cables exist? I'm facing a similar issue you had, and I couldn't find anything useful so far. Physically it is possible to fit 2 flat riser cables, but they would be an eyesore to look at.
