Router LAN port 1 not working!
DaNTe07
58
Hi,
Until a last few days my router was working fine but suddenly this morning it stopped working.
The light on LAN port 1 is not glowing so I think the issue is with the port itself.
I tried connecting to other ports, the light is glowing but I am not able to connect to internet with any of them.
When I directly use the cable to PC it works, so the internet is working, just the router having issues.
My Router is d-link DIR-600M.
Thanks
The warranty period is one year in the US and Canada according to THIS data sheet, however it is longer in other locations -- for example it is three years in India per the Amazon India web site.
You will need to contact your regional support for a replacement to determine if you can get a replacement via RMA if you are eligible.
