Hello, i have a weird problem with my router yesterday i noticed it seemed like it was going slower then it usually does so i went and did a speed test at speedtest.net an it was way slower then what im paying for so i called my provider an they had me hook it straight to the pc an the speeds were fine, i told them i had vonage an they said it was the vonage router causing the problem an they couldnt help me with that so i said no problem id call vonage, well before i called vonage i decided to just hook the wireless router without the vonage router, still crappy speed so i went in and reset my wireless router, still no good, so my router has a switch to turn off the wireless on the back an i turned it off, now i get full speed again, turned the switch back on so my wireless stuff works crappy speed again on my pc, turned wireless back off reconnected my vonage router( it an my pc are direct connected to wireless router) still have full speed dl an ul, turn back on wireless switch everything goes crappy again. never had any problems till yesterday, havent added anything, havent dl any viruses that i know of scanned for them didnt find anything. any help would be appriciated. Its a trendnet tew 639gr router, an 50m dl/ 2m ul that goes as low as 5m dl/ 500k ul not that thats bad but it sucks when you are paying for the faster speed. Thanks Again, Roy
