[SOLVED] RSMB blackscreen sony vegas 16 render issue
Sep 8, 2020
A few days ago I purchase sony vegas 16, and I wanted to use rsmb on one of my videos but the thing is it renders some parts with rsmb and then the other part is just a black screen.
I tried reinstalling trying new settings but nothing has fixed it yet. Some people said it was my pc but I have a alright pc (Ryzen 7 3700x, GTX 1060 6GB, 16GB ram). I also tried to render without no rsmb and it worked without problems. Anybody had the same issue? if so please tell me how you fixed it, I will greatly appreciate it.
I had the same problem, but I managed to get out of it.
Let me explain the process.
  • Click on "Render as".
  • Select a rendering model
  • Click "Customize Template" at the bottom of the render types.
  • Under "Variable bit rate", you will find "Encoding mode". Click on the scroll bar, and select "Render using CPU only".
And that's it! No more error messages!
