Hello!
So I am currently having an issue with my GALAX GeForce® RTX 2060 EX White (1-Click OC) where I would usually get black screens. Either my main monitor (AOC G24G2E running 144hz through Display port 1.1) or my second monitor (HP Z24i g2 running 60hz through HDMI to DVI). Sometimes both would turn black without the monitors indicating that there is no display. The problem runs for roughly 1 second then the display(s) returns to normal. Moreover, this happens randomly like either during regular web browsing, gaming, or doing schoolwork. This also happens around once every 1-2 hours.
GPU runs in normal temps and never exceeds 80 degrees Celcius when gaming afaik. Never overclocked it too. This started happening on April 19 when I got my new monitor (the HP one). At first, it was the second monitor blacking out, then later on both monitors blackout as said previously. There were also times that the second monitor would blackout then display "static" like an old tv having no cable signal. Replugging the display cable fixes it when that problem occurs.
Solutions I have tried:
Updating GPU drivers using Nvidia Geforce(using the latest 466.27 as of 5/2/2020)
Updating Windows 10
Changing hardware (CPU, MOBO, and RAM)
Re-plugging display cables
Computer specs:
CPU: AMD Ryzen 5 3600(stock clock)
RAM: G.Skill 2x8Gb clocked to 3200mhz
MOBO: MSI B450M Mortar Max
GPU: GALAX GeForce® RTX 2060 White (1-Click OC)
STORAGE: 500Gb Samsung 860 EVO SSD (Boot drive), 120Gb 850 EVO SSD, Two 1Tb WD Caviar Blue HDD
PSU: EVGA 600B 80+ bronze
OS: Windows 10 Home Version 20H2
Are there any fixes that I could do? The card is still under warranty although the store that I bought it from only offers service warranty (I purchased it from the Philippines btw).
Updating Windows 10
Computer specs:
