Hey there !
I replaced my old gtx 960 with a brand new rtx 2060 from KF2A, because i wanted to make my computer ready for VR...
But theres some kind of fps problem... the rtx 2060 runs gpu - expensive games without any problems on max settings, but has massive struggles with "simple" games.
Im using Xeon W3550 for the stats down under... he isnt a bottleneck, never had a load above 40% while playing games. The gpu itself had only a load of about 100% when playing star wars battlefront...
2060 - Starwars Battlefront 2 ( 2018 )
Resolution : 1080p
Settings : Ultra with Raytracing
FPS : 90 - 100
2060 - Minecraft
Resolution : 1080p
Optifine installed
No shaders or resource pack
Settings all on fast without vsync
FPS : 100-200 massive drops
960 - Minecraft
Same settings as above
FPS : 400-500 mostly
2060 - Minecraft with shaders
FPS : 40-60
960 - Minecraft with shaders
FPS : 100-200
So it seems like my rtx 2060 is only good at gpu intensive games, but sucks on minecraft... how is this possible ?
I already made a clean driver install using ddu, adjusted the nvidia control panel settings etc.
Does anyone have a idea what i can do ?
Resolution : 1080p
FPS : 90 - 100
2060 - Minecraft
Resolution : 1080p
Optifine installed
960 - Minecraft
FPS : 40-60
FPS : 100-200
