[SOLVED] Rtx 2080 psu need help
Ahmed_Khaleel
21
Hey guys i will buy the x trio version of rtx 2080 and i want know if my seasonic SeaSonic - EVO Edition 620 watt will be ok for new gpu i bought this psu from a year for my asus rog strix 1070 now my pc spec : i7 8700k oc 4.7 mother board msi x370 a pro and gpu asus tog strix 1070 nzxt cooler x42 4 ssd , 2 mechanical seagate 7200 rpm and samsung 960 m2 and hue +with 2 aer fans 120 and 2 led strips my gpu use 175 watt during gaming and rtx uses 225 will this difference affect the stability or not enough since 1080ti use almost 270 watt and nvdia recommend 600 watt psu i know my psu is not famous or rated as evga but can it handle my current system for few months and i will change soon after that
Those numbers are extreme but any way you will never see that it normal use. Even the high for gaming is just a single spike and substantially lower.
