Question RTX 2080ti Lightning Z - GPU fans running at different speeds/RPM, help?
Mar 3, 2019
View: https://imgur.com/IMh2exF
This is a brand new card, I had it for over a week and had just have this problem today.
As soon as my GPU temp hits 74-75% my first GPU fan's RPM would jump up to 3.3-3.5k from 2.1-2.3k, and fluctuate back and forth between those two threshold non stop.
It seems to cap at 51-52% fan speed as well, is my card broken or is there a fix, maybe MSI Afterburner can help? Is this something I can fix with a driver? Thanks.
Nice card! Try uninstalling the driver with DDU
https://www.guru3d.com/files-details/display-driver-uninstaller-download.html
Make sure you have the latest motherboard BIOS for your motherboard.
Install afterburner.
Call MSI support to make sure this is how the card funtions. Doesn't seem like a big deal to me as long as the card is quiet enough for you and is giving you 1920 MHZ. With Afterburner you can modify the Fan speeds and set custom curves...
