Hello friends,
For every time my video card officially sounds like the sound of airplane takeoff, it does not matter the cycle. So, i manually turned on and off the fans (2 pieces) to test this and the result i reached is as follows;
My system is new, the default settings apply; i didn't make any changes. Is this a problem or is there a setting i need to change? Thanks in advance.
- The fan is perfectly normal, does not disturb even at 80% rpm, works silently.
- As for the fan, it works at 100% regardless of the rev setting i set, and i can't see the RPM value from any program, it's looks "0" rpm but it runs at 100% rpm and makes great noise (this is the source of the sound)
