Hi. I have a Zotac RTX 3060 Ti Twin Edge OC and I had this for a little while now. Yesterday I tried running Heaven Benchmark to see my peak wattage using HWiNFO64 and GPU-Z. After running the test I noticed when the fans went back down to 0 RPM, the reading would abruptly go to some 184,000 RPM. It shows both on HWiNFO64 and GPU-Z. They won't stay there though, it just shows up in milliseconds then back to hundreds of RPM again. I tried observing the fans when they go from 0 to hundreds RPM and they appear normal to me. But the RPM reading is just crazy. The card works well too. I never had any issues with it when rendering or gaming.
Could this be just a bad sensor or is there anything more serious that I need to worry about it in the future? The card is not overclocked or anything. All stock settings. Any insight would be greatly appreciated. Thanks!
