[SOLVED] RTX 3070 JetStream OC power connection
Fiorezy
Notable
Jul 3, 2020
376
86
890
So I got the Palit RTX 3070 JetStream OC last week which have 2x8 pins, my PSU is the Corsair 650i which have 2 PCI-E cables of 8 pins to dual 8 pins (6+2) like this one, so I plugged all the pins using just one cable but when testing power consumption in games, I got 160W in Valhalla and 240W in The Division 2 at 1080p ultra unlocked fps, is this normal for this card or should I use 2 cables instead?
If your PSU shipped with PCIe cables that split into dual 8 pin cables, than plugging it in like that is how the PSU is designed to be used. No need to overthink it.
If you can use 2x8-pin do that. Or 1x8 and a 6+2 one. The RTX 3070 has a TDP 220 Watts depending on your model it can be slightly more or less. So it should be fine. You can try undervolting but that usually only helps AMD cards.
Reactions: Fiorezy
Reactions: Fiorezy
