[SOLVED] RTX 3070 not detected please help
AC3B00G13
65
4
4,545
Hello recently Installed RTX 3070 to my PC Plugged everything in normally and powered up I can see the RGB Light turn on and fans only spin at boot then stops immediately. Windows doesn't detect new GPU and is using Microsoft basic adapter. I installed the drivers from the booklet but where do I put them if it doesn't detect the GPU device itself. Please help
PC Components
Motherboard: Z370 - A PRO
CPU: Intel 8700
PSU: EVGA 700W
Try reseating the card make sure everything is plugged in properly
Hey Ac3,
So I think im having the same issue. 3070 fans not spinning, but lights are on. I cant download any drivers for it because they arent compatible. Wondering how you did that
Reactions: AC3B00G13
After reinstall windows and all drivers, my card ( RTX 3070 inno3d chill x4) is working perfectly fine, but now pc, time to time ,rebooting himself during playing games.
Hey Ac3,
Make sure you download the drivers from the brand of the GPU you got. For example I downloaded the driver's from Gigabytes Website under my selected card.
Also still use the DDU and uninstall any previous driver's. Then download the drivers.
Or it might have been a counterfeit GPU.
