Question RTX 3070 usage and FPS issue
ZombieMan_1
24
Pc: R5 3600 4.2ghz 1.15V
GPU ZOTAC AMP HOLO 3070 base no oc
PSU: CMPSU-650TX 650W
DDR4 3200 16gb
Regardless of setting my 3070 in warzone doesn't use all the gpu at 1080p 144hz. the most i have seen is around 95usage in the plane scene but after it drops to 40-70 usage range. I average around 100-120fps on the outer areas of the map. but in downtown i go to about 90-100fps range. i have reinstalled the game and my gpu drivers already and both didn't fix it. my cpu usage is a bit high like 40-80% at times. any help?
Edit:
View: https://youtu.be/WUma7AxStPg?t=159
This guy on yt back in dec, ran the same setup as mine and got 145 average.
edit2: i also seen that warzone is also using almost all my ram about 95% and even times 97% of my ram being used on warzone. but no stuttering or anything coming from it.
Could be the driver overhead issue on Nvidia GPUs that hardware unboxed is talking about. GeForce GPUs apparently tax the cpu more. Have you tried playing at higher settings? As this would make the game more GPU bound and less CPU straining
ye i have tried higher settings and 1440p still same fps around 100
You cannot directly compare a Youtube video to your setup, what is his RAM and its settings, what cooling has he got, is someting in the bios settings changed etc etc..... 100 fps is kinda what I would expect from a 3600 six core at 1440p. This video will give you an idea of whats going on... I feel too many think "ah I get a RTX or Big Navi card and the FPS will be UNLIMITED" and a re disappointed when they find it is not the case.
View: https://www.youtube.com/watch?v=JLEIJhunaW8
Well idk also I'm at 1080p 144hz but I havent had a issue with most games I have played except warzone. So I think it either warzone or Nvidia drivers. My gpu is running normal and getting enough power from the psu. As well as Temps for both cpu, gpu. don't go past 65c in gaming for hours.
