Question RTX 3080 but low FPS
IceAge1992
26
Hello,
I hope everyone is doing well today. I kindly ask for your assistance because my PC is running a few games at incredibly low frame rates compared to an RTX 3080. I'm not an expert on pcs, so that's why I'm here, but I think my CPU might be the bottleneck in my system. Any response, please, would be helpful.
Should I switch to an i9?
PC spec :
GPU : RTX 3080 12GB.
CPU : Processor 12th Gen Intel(R) Core(TM) i5-12600K, 3700 Mhz, 10 Core(s), 16 Logical Processor(s).
Motherboard : BaseBoard Product TUF GAMING B660-PLUS WIFI D4.
RAM : 32GB.
Windows 10 !
playing on resolution 1080p
Kindly excuse any grammar mistakes. English is not my native tongue.
It is safe. You can wait for others to say the same, also. It's good to be cautious.
This is the outcome:
UserBenchmarks: Game 8%, Desk 72%, Work 9%
CPU: Intel Core i5-12600K - 84.4%
GPU: Intel UHD Graphics 770 - 4.2%
SSD: Kingston SSDNow UV400 240GB - 56.2%
HDD: WD Blue 1TB (2012) - 85.8%
RAM: Corsair CMH32GX4M2D3600C18 2x16GB - 46.9%
MBD: Asus TUF GAMING B660-PLUS WIFI D4
is it correct?
is it correct?
It gives you an option at the end to share a link. That's what we need.
Actually, connect monitor to 3080 and NOT the motherboard..
I can tell my PC performing much better than before, but I think this is because I'm playing in 1080p while my graphics card was designed for 2K or higher resolutions (Maybe). I'm not sure why I can't get my GPU usage at least 90% ( for same games )
@1080p you are likely being CPU limited. A 3080 is currently kinda overkill 1080p.
But your CX750m is not a good option for a 3080. If you do make a change that pushes the card harder(best option imho would be a 1440p monitor) then good chance its transient spike will trip the PSUs protections.
So I should replace my power supply and buy a new monitor with a resolution of at least 2K?
I can do that, but what power supply do you suggest for my computer?
