Does the Cooler Master MasterWatt 750 have everything needed to run the 3080
including the 12 pin power connector plug?
The 12-pin power adapter comes with the GPU.Does the Cooler Master MasterWatt 750 have everything needed to run the 3080, including the 12 pin power connector plug?
That depends on what's expensive to you and what options do you have.that isn't too expensive?
https://www.tomshardware.com/reviews/antec-earthwatts-gold-pro-750w-psu,5429.htmlSo the "Antec EarthWatts Gold EA750G Pro 750W" is a good buy? It's around my budget.
