Question RTX 3090 Founders Edition has any problems?
barista
11
Hello, i'm planning to buy RTX 3090 FE on used second hand. Is there any chronic problems? Do you suggest this model?
I can't buy Strix-Suprim-Evga etc. I don't have enough money. By the way FE looks so goood.
I can buy this models:
-Zotac Trinity,
-PNY XLR8
-Ventus 3X
-FE.
Buying used GPU can be very risky because you never know how the owner treated it. You have to be 100% make sure owner sends proof that its working inspect the gpu before buying. Also buying 3090 is powerful GPU so you also need to think about your computer specs PSU and CPU
Reactions: barista
Yeah i'll test driver uninstall-install, GPU-Z, Furmark (with core + mem temp), fan noise test stop-start-stop test etc.
Yes i know my CPU will do very high bottleneck but i will buy 2K 165HZ monitor next year or if i move Germany, i would like to buy Ryzen 7 8000X or i7 14-15th gen platform.
I buyed FSP Hydro G PRO 750W 3 month ago,
My setup:
12100F
8x2 3200 CL16 Ballistix,
H610M-B
Excaria Plus 500GB,
Mesh case with 4 fan (32.5CM for GPU support)
VX2458 C-MHD
